Top » Home Shop » Vacuum Cleaner » Spare Parts for Vacuum Cleaner » CE-9810 ALIGN Wet/Dry Vacuum Cleaner » BB04092
€ 70
1015/9810 Motor
BB04092
1015/9810 Motor
€ 88.99
Instructions: Available:
● High efficiency single stage/speed carbon brush motor.
● Voltage: 110V 60Hz.
● Power consumption: 800W.
● Dust collection efficiency: 120W.
● Power supply is 110V only. An incorrect voltage will burn out the motor.
● When the vacuum cleaner is turned on, please make sure that the filter and the filter rack are properly installed to prevent dust entering motor directly and burn causing the motor burn out.
● For more precaution and maintenance of the vacuum cleaner, please refer to instruction manual.
● AVC-9810
● CE-32
Float - Small
€ 2.99
1 x 'Float - Small' order
Float Rack - Black
€ 5.99
1 x 'Float Rack - Black' order
1040/1060 Motor
€ 116.99
1 x '1040/1060 Motor' order
This Product was added to our catalog on Saturday, 17. July 2010.
