Top » Home Shop » Vacuum Cleaner » Wet & Dry Vacuum Cleaner » BB01017
€ 173
ALIGN Wet/Dry Vacuum Cleaner AVC-2015
BB01017
€ 188.99
Instructions: Specification:
● Two-layer turbo motor, 2-step power switch
● High density dust filter
● Auto cord reeling
● 360° flexible hose
● 360° turnable base with accessory storage
● Easy and convenient accessories storage
● Patented diversion cover keeps from water spilling
● 2-color soft wheel won’t harm the floor
● Suction indicator shows the vacuum efficiency
● Fixing button keeps the flexible hose firmed
● Vacuum adjustable with the valve on hose end
● Rating Voltage:AC 110V 60Hz
● Power consumption:900/600W
● Vacuum efficiency:170W
● Tank capacity:15 liters
● Package weight:8.86kg
● Package size:33×34×56cm
● Φ32mm B master nozzle×1pcs
● Φ32mm flexible tube(material: EVA)×1pcs
● Φ32mm wet nozzle(material: ABS)×1pcs
● Φ32mm wand(material:SUS 304)×1pcs
● Φ32mm wand(material: ABS)×1pcs
● Φ32mm crevice nozzle(material:PP)×1pcs
● Φ32mm 360°round nozzle(material:PP)×1pcs
● Φ32mm unobstructing nozzle (material:PP)×1pcs
● Φ32mm triangle nozzle(material:ABS/AS)×1pcs
● user’s manual×1
● warranty card×1
This Product was added to our catalog on Tuesday, 30. March 2021.
