Top » Home Shop » Vacuum Cleaner » Wet & Dry Vacuum Cleaner » BA01003
€ 147
TOSHIBA Wet/Dry Vacuum Cleaner TVC-2215
BA01003
€ 188.99
Instructions: Specification:
●Two-layer turbo motor, 2-step power switch
●High density dust filter
●Auto cord reeling
●360° flexible hose
●360° turnable base with accessory storage
●Easy and convenient accessories storage
●Patented diversion cover keeps from water spilling
●2-color soft wheel won’t harm the floor
●Suction indicator shows the vacuum efficiency
●Fixing button keeps the flexible hose firmed
●Vacuum adjustable with the valve on hose end
●Optional parts:2215 Filter
●Rating Voltage:AC 110V 60Hz
●Power consumption:900/600W
●Vacuum efficiency:170W
●Tank capacity:15 liters
●Package weight:8.86kg
●Package size:33×34×56cm
●Φ32mm B master nozzle×1pcs
●Φ32mm flexible tube(material: EVA)×1pcs
●Φ32mm wet nozzle(material: ABS)×1pcs
●Φ32mm wand(material:SUS 304)×1pcs
●Φ32mm wand(material: ABS)×1pcs
●Φ32mm crevice nozzle(material:PP)×1pcs
●Φ32mm 360°round nozzle(material:PP)×1pcs
●Φ32mm unobstructing nozzle (material:PP)×1pcs
●Φ32mm triangle nozzle(material:ABS/AS)×1pcs
●user’s manual×1
●warranty card×1
This Product was added to our catalog on Thursday, 01. April 2021.
