Top » Home Shop » RC World » Aerial Photography / Mission Drone » Battery » HBP20001
US$ 75
Li-Po Battery 4S 2000mAh
HBP20001
US$ 79.99
Instructions: Specification:
●Suitable for Handheld Rig.
●It contains the power switch. Power ON/OFF: Press and hold power button for 3 seconds.
●LED shows battery status and capacity.
●While no charging and discharging after power on, the power will automatically shut down after 10 minutes.
●With short circuits and reverse polarity portection to prevent any battery damaged.
●The protection will be activated when each cell voltage is lower than 3.5V.
●With overload relay protection.
NOTE:
Do not charge immediately after the battery is fully depleted. Allow it to cool down and inspect it before charging. If against follow the original factory using rules, possibly cause the battery to inflate or any dangerous accident happens.
●Output: 14.8V 2000mAh 29.6Wh(4S1P)
●Dimension: 102x40x36mm
●Weight: Approx. 230g
●Max current: 1.5A
This Product was added to our catalog on Thursday, 03. September 2015.
