Top » Home Shop » RC World » Aerial Photography / Mission Drone » Battery » HBP33003
US$ 39
Li-Po Battery 6S 3300mAh
HBP33003
US$ 109.99
Appearance:
●Suitable for T-REX 500~T-REX 600.
●These high discharge lithium polymer batteries are designed to maintain performance in series configuration, and can be charged individually through balancing plug. The extreme high capacity are catered specifically for applications requiring longest flight duration, Suitable for extreme maneuver flight needed.
●Max Continuous Discharge: 50C.
NOTE:
●Output:22.2V 3300mAh 73Wh (6S1P)
●Support 5C charging.
●Dimension:140x43x43mm
●Weight:530g(Including connectors)
●Max Continuous Discharge:50C
●Amass XT60-F Connector
This Product was added to our catalog on Wednesday, 15. January 2014.
