Top » Home Shop » RC World » Aerial Photography / Mission Drone » Battery » HBP13001
€ 7
Li-Po Battery 3S 1300mAh
HBP13001
€ 13.99
Appearance:
MR25 Power Tip:
Align Motor Battery
Propeller
5040
[MP05032]
5045
[MP05031]
6040
[MP06031]
RCM-BL1806
[HML1806M01]
[HML1806M02]
3 Cell
[HBP13001]
[HBP18001]
V V V
4 Cell
V V Prohibited
RCM-BL2205
[M425022XXW]
[HML2205M01]
[HML2205M02]
3 Cell
[HBP13001]
[HBP18001]
V V V
4 Cell
V V Prohibited
●Suitable for MR25 series.
●This Li-poly battery features high efficient and high discharge, use a inspection machine to match packs, suitable for other professional model airplanes, cars, and guns.
●Max Continuous Discharge: 30C(39A).
NOTE:
●Output: 11.1V 1300mAh 14.4Wh(3S1P)
●Support 5C charging.
●Dimension: 70x29x21mm
●Weight: 99g
●Amass XT60-F Connector
This Product was added to our catalog on Friday, 16. October 2015.
