Top » Home Shop » RC World » Aerial Photography / Mission Drone » Battery » HBP14501
US$ 9
Li-Po Battery 6S 1450mAh
HBP14501
US$ 32.99
Appearance:
●Suitable for TREX 450 6S.
●This Li-poly battery is using series/balancing design, features high efficient and high discharge, use a inspection machine to match packs(450MX Brushless Motor 1800KV).
●Max Continuous Discharge: 45C.
NOTE:
●Output:22.2V 1450mAh 32.2Wh (6S1P)
●Support 5C charging.
●Dimension:115x34x28mm
●Weight:230g
●Amass T Plug-F Connector
This Product was added to our catalog on Thursday, 31. October 2013.
