Top » Home Shop » RC World » Agricultural Drone » Agricultural Drone Electric Equipment » HEG00023
US$ 157
12S Pump – T22
HEG00023
12S Pump – T22
US$ 86
Appearance:
●Suitable for ALIGN M6T22.
●The high-pressure pump is specially designed for agricultural spraying. The internal motor spindle adopts a 3-bearing fixed design, which greatly improves the stability of the pump during operation and effectively extends the service life.
●Enlarged metal motor mount design, structural strength is improved, the spraying pressure of the pump is more constant, and the heat dissipation function of the pump is provided when the pump is running, so that the pump water output can be increased up to 5.5L/min.
●MOSFET with independent micro drive chip, withstand current 10A, small but support powerful output, fast response 10 times faster than the general MOSFET in the market.
●Supply Voltage:DC48-58.8V(12-14S)
●Power Consumption:1.2A
●Max. Amount:5.5L/min
●Max. Operating Pressure:0.53MPa
Content:
●12S Pump x 1
This Product was added to our catalog on Wednesday, 30. June 2021.
