Top » Home Shop » RC World » Agricultural Drone » Agricultural Drone Batteries » HBP22005
US$ 4
Li-Po Battery 6S 22000mAh
HBP22005
US$ 359.99
Appearance:
Appearance:
●Suitable for ALIGN M6T22/M4/M6/E1 PLUS Agricultural Drone.
●Max Continuous Discharge: 35C.
AS150U-F New Connector
●Effectively prevent the spark while plugging in battery also reduce the damage of electronic equipment and connector plugs.
●Newly add waterproof rubber on the bottom of the connector, and the rear welding part is covered with rubber to effectively prevent the penetration and corrosion of the pesticide.
●Enlarge the diameter of the internal gold plating connector and the contact resistance can be lower than 0.2mΩ
NOTE:
●Output:22.2V/22000mAh 488.4Wh(6S1P)
●Support 5C charging.
●7-pin plug
●Dimension:205x92x70mm
●Weight:2730g
●Max Continuous Discharge:35C
●AS150U-F Connector
Content:
●Li-Po Battery 6S 22000mAh x 1
This Product was added to our catalog on Thursday, 12. August 2021.
