Top » Home Shop » RC World » Aerial Photography / Mission Drone » Brushless Motor » HML6215M02
US$ 411
M8 Brushless Motor - counter clockwise(180KV/6215)
HML6215M02
US$ 275
Appearance:
●Suitable for 2388 Propeller.
●Suitable for Outside Diameter of Carbon Fiber Arm:φ30mm/φ28mm (Motor adapter is required for usage.)
Power System
●The power system integrates motor and ESC into a lightweight structure. The motor is designed with closed system; the ESC is designed with full potting protection and with waterproof and anticorrosive connector plug/pins.
Super Bright LED Lights
●The bright LED lights allow for pilots to check drone’s heading direction and flight status at day and night. (There are total 7 colors for users to switch from.)
●Max. Tensile Force: 12kg/Set (48V)
●Recommended Battery: 12S (LiPo)
●Recommended Takeoff Weight: 3~5kg/Set(48V)
●Powertrain Weight: 720g
●Working Environment Temperature: -20~50℃
Motor
●Outside Diameter: 70mm
●KV Value: 180KV
●Bearing: Imported Bearing
ESC
●Support Battery: 6~12S LiPo
●PWM input Signal Level: 3.3V/5V(Compatible)
●Signal Frequency: 50~500Hz
●Operating Pulse Width: 1100-1940μs (Cannot be programmed)
●Max. Input Voltage: 52.2V
●Sustained Ceiling Current: 80A
●Surge current: 100A(10s)
●BEC: No
●Screws for nozzle assembly: φ28.4mm-2xM3
Content:
●M8 CCW Brushless Motor(counter clockwise) x 1
This Product was added to our catalog on Tuesday, 14. September 2021.
