Top » Home Shop » RC World » Agricultural Drone » M6T22 Parts » M616066XXW
US$ 2,105
ALIGN 40L Fertilizer Spreader Turntable
M616066XXW
US$ 429
Appearance:
Appearance:
Appearance:
Size:
●Suitable for ALIGN M4/M6/M6T22/M4T12 and other fertilizer spreaders in the market.
●Suitable for granular container with 120~121mm diameter.
●ALIGN brand new developed fertilizer spreader V2, max. spread volume 40kg Fertilizer/min with adjustable spread volume for even spreading, time saving and high efficiency.
●The fertilizer spreader turntable is easy to exchange and clean. The powertrain adopts high carbon steel material with reliable one-stage coaxial gear for lowing speed. It’s lighter but bigger torque, also make the structure simple to prevent any possible gear worn out or heat issue and improve power consumption during operation. (Unlike the average two-stage gear for lowing speed in the market) The turntable utilizes industrial plastic steel fiber material, that is much sturdy and durable. 210 degree one-direction spreading allow to protect relevant electrics from damage. As during spreading, granular usually spread out powerfully and non-directionally that often damage the electrics backwards, such as battery or signal cables... etc.
●Max. Spray Range: Width 12M/Front 6M
●Spraying angle: 210 degrees
●Max. Spread Volume: 40kg Fertilizer/min
●Spread Volume: Percentage adjustable setting
●Suitable for 1 cm granular spread
●Input Voltage: DC12V
●Operating Current Consumption: 2.5A
Content:
●40L Fertilizer Spreader Turntable x 1
This Product was added to our catalog on Thursday, 28. October 2021.
