Top » Home Shop » RC World » Agricultural Drone » Agricultural Drone Charger » HEC00007
US$ 11
UP2600+ Balance Charger
HEC00007
US$ 715
Instructions: Specification:
●UP2600+ Balance Charger has dual charge management system designed for Align Agricultural Drone, charging either two 12S Li-Po battery or Li-HV battery and storage battery in the meantime. Intelligent and easy to charge at one button.
●Support two sets of battery with 12~14 cells (LiPo / LiHV / Intelligent Battery).
●Charging Current : 10A/15A/25A/35A/50A
●Balance charging mode and storage (maintain) mode.
●Remember last time charging current
●Multiple Protection Functions: Overload Protection, Overcurrent Protection, Reverse Polarity, Temperature Protection
NOTE:
3.Before placing your order, please make sure to confirm local voltage for buying correct input voltage charger to prevent any unexpected danger and fire resulting from wrong voltage input.
4.Keep the charger and battery away from flammable items.
5.Never leave the charger unattended, in case of causing an accident.
6.The battery should be charged under 5-40 degree Celsius environment.
7.Keep the charger away from dust, moist, rain, heat, direct sunshine and vibration.
8.Before you power off the charger, please “stop” the charger first, unplug the battery, then unplug the power cord of the charger.
AC Input Voltage:AC 220V
●Charging Ports:6 ports
●Charging Power:2600W(1300Wx2)
●Support Battery Type:12S~14S LiPo/LiHV/Intelligent Battery
●Charging Current:10A/15A/25A/35A/50A
●Discharging Power:140W(70Wx2)
●Balanced Current:1.5A/Cell
●Output Voltage:DC 44.4~58.8V
●Protection Functions:Overload Protection/Overcurrent Protection/Reverse Polarity/Temperature Protection
●Display:LED Indicator+LCD Intelligent Display
●Size:280x165x240mm
●Weight:6.8kg
Content:
●UP2600+ Balance Charger X 1
●Partial Pressure Board x 2
This Product was added to our catalog on Wednesday, 01. December 2021.
