Top » Home Shop » RC World » Agricultural Drone » Agricultural Drone Electric Equipment » HEG00024A
US$ 157
14S Pump
HEG00024A
14S Pump
US$ 86
Appearance:
●Suitable for ALIGN Agricultural Drone.
●ALIGN M4/M6/E1 PLUS Agric. Drone/Heli can use signal cable for upgrade.
●The high-pressure pump is specially designed for agricultural spraying. The internal motor spindle adopts a 3-bearing fixed design, which greatly improves the stability of the pump during operation and effectively extends the service life.
●Enlarged metal motor mount design, structural strength is improved, the spraying pressure of the pump is more constant, and the heat dissipation function of the pump is provided when the pump is running, so that the pump water output can be increased up to 4.5L/min.
●MOSFET with independent micro drive chip, withstand current 10A, small but support powerful output, fast response 10 times faster than the general MOSFET in the market.
●Supply Voltage:DC48-58.8V(12-14S)
●Power Consumption:1.2A
●Max. Amount:4.5L/min
●Max. Operating Pressure:0.53MPa
Content:
●14S Pump x 1
●Signal Cable x 1 (Length:120cm)
This Product was added to our catalog on Tuesday, 25. October 2022.
