Standard Equipment
●ALIGN E1 V2 Kits Set x 1 set
●900mm Carbon Fiber Blades x 1 set
●115mm Fiber Tail Blades x 1 set
●Transmitter set x 1
●Main Power - 1000MX Brushless Motor(350KV) x 1
●180A ESC Brushless Motor Controller x 1
●DS830M High Voltage Brushless Servo x 3
●DS820 High Voltage Brushless Servo x 1
●AP6 Flight Controller System x 1
●GNSS/RTK Receiver x 1
G2A 1080 2-axis Gimbal x 1
●Super Bright LED Front Headlight x 1
●Enhanced Control Hook x 1
ALIGN E1 V2 Specification
●Body Length:1600mm
●Body Height:560mm
●Body Width:345mm
●Main Rotor Length:900mm
●Main Rotor Diameter:1986mm
●Tail Rotor Diameter:303mm
●Power Motor:MX1000 (350KV)
●Weight(Without Battery):Approx. 7.6kg
●Unladen Weight:13kg(Include 22000mAh Battery)
●Max. Take-off Weight:24.9kg
●No-load Flight Time: about 43min (With 22000mAh Bettery)
Self-provided Equipment
Balance Charger
●Main Power Battery 6S 22000mAh x 2 pcs
