Top » Home Shop » RC World » Lawn Mower » Lawn Mower Parts » LGA22080AXW
US$ 200
G22X Tri-Blade Cutter Set
LGA22080AXW
US$ 64
Appearance:
Appearance:
Appearance:
Instruction: Content:
●Suitable for G22X/GA22X Lawn Mower.
●The Blade Fixing Plate is made of 4mm high-strength carbon steel for enhanced durability and impact resistance.
●The 5mm thick double-edged blades are made of heat-treated high carbon steel, providing good inertia. When cutting through heavy resistance, the engine is less likely to stall. The impact force and resistance from hitting large stones are also significantly cushioned.
●The blade-locking screws feature enlarged heads to improve blade mounting stability.
●Must with G22X/G45X Blade Screw Parts(LGA45062XXW)。
●G22 Tri-blade Fixing Plate x 1 (Thickness 4mm)
●G22/G45 High Carbon Steel Horizontal Blade x 3 (165mm/Thickness 5mm)
●Socket Button Head Collar Screw x 3(M10x26mm)
●M10 Nut x 3
●Washer x 3(Φ12xΦ24x2mm)
●Spring Washer x 3(Φ10xT2mm/12.9 Grand)
This Product was added to our catalog on Thursday, 15. January 2026.
