Top » Home Shop » RC World » Agricultural Drone » Agricultural Drone Batteries » HBP22013
US$ 73.99
Li-Po High Voltage Battery 6S 22000mAh
HBP22013
US$ 318
Appearance:
Appearance:
●Suitable for ALIGN Agricultural Drone/M4P Mission Drone/E1 V2 Mission Helicopter use.
●Max Continuous Discharge: 15C.
AS150U-F New Connector
●Effectively prevent the spark while plugging in battery also reduce the damage of electronic equipment and connector plugs.
●Newly add waterproof rubber on the bottom of the connector, and the rear welding part is covered with rubber to effectively prevent the penetration and corrosion of the pesticide.
●Enlarge the diameter of the internal gold plating connector and the contact resistance can be lower than 0.2mΩ
NOTE:
●Output:26.1V/22000mAh 574.2Wh(6S1P)
●Support 1C charging.
●Dimension:205x90x57mm
●Weight:2410g
●Max Continuous Discharge:15C
●AS150U-F Connector
This Product was added to our catalog on Tuesday, 23. June 2026.
