Top » Home Shop » RC World » Aerial Photography / Mission Drone » Charger/Battery » HBP10008A
US$ 36
M460 Intelligent Battery 6S 10000mAh
HBP10008A
US$ 200
●Suitable for M460 / M490.
●Brand new 10000mAh high efficiency battery for 28 minutes. Delicate outfit and all-in-one quick release battery mounting plate. The battery indicator light shows current battery capacity by pressing the power button.
●These high discharge lithium polymer batteries are designed to maintain performance in series configuration, and can be charged individually through balancing plug. The extreme high capacity are catered specifically for applications requiring longest flight duration, Suitable for extreme maneuver flight needed.
NOTE:
●Output:22.2V 10000mAh 222Wh (6S1P)
●Support 5C charging.
●Dimension:215x55x67mm
●Weight:1170g
This Product was added to our catalog on Wednesday, 30. September 2026.
