Top » Home Shop » RC World » Aerial Photography / Mission Drone » Aerial Photography / Mission Drone » Aerial Photography Helicopter » Helicopter Gimbal Equipment » G800 Parts » H80B036XXW
€ 4
G800F Aerial Gimbal System Combo
H80B036XXW
€ 1,966.99
Focus Shot1(Fiberglass composite material matched with high strength aluminum alloy to form the gimbal backbone) Focus Shot2(High rigid gimbal bottom plate and gimbal camera tray supporting pole that featuring high precision, high stability, capable of high payload, and is able to sustain hard landing of helicopter) Focus Shot3(Utilizes with 540 degrees DS815 servo and belt transmission design, the gimbal is capable of wider turning angles with higher precision)
Focus Shot4(New GS850 Controller support with 5 operating modes and various functions as usual, further equipped with built-in PAN, ROLL and TILT gain dials enable immediate attitude compensating reaction based on different weight of photograph equipment. Featuring much higher degree of control precision) Focus Shot5(Unique gimbal support assembly design, with aesthetic pleasing clean look, featuring high precision and slop free and makes the camera lens maintain at the same angle in flight) Focus Shot6(Shock absorbing dampers designed specifically for Align G800F gimbal system, and various spring tensions can be used according to payload)
Focus Shot7(Gimbal Accessory) Focus Shot8(Gimbal Shock Accessory) Focus Shot9(Gimbal Camera Pad )
Focus Shot10(ESC Mount) Focus Shot11 (GS850 Controller) Focus Shot12 (DS815 HV Robor Srevo)
Package1:
Package2:
Instruction: Specification (DS815 HV ROBOT SERVO):
●Align G800F gimbal is an upgrade product catered specifically for the needs of aerial photography. The included GS850 gimbal controller features high power computing capability, and various control modes to precisely lock into the shooting object, as well as meet the needs of various other aerial photography needs, allowing optimal imagery to be obtained easily. This system must be used in conjunction with Align's APS gyro and T-Rex 800E. Fiberglass composite material matched with high strength aluminum alloy to form the gimbal backbone, featuring high precision, high stability, capable of high payload, and is able to sustain hard landing of helicopter. When paired with 540 degrees DS815 servo and belt transmission design, the gimbal is capable of wider turning angles with higher precision.
●Unique gimbal support assembly design, with aesthetic pleasing clean look, featuring high precision and slop free and makes the camera lens maintain at the same angle in flight.
●Shock absorbing dampners designed specifically for Align G800F gimbal system, posses superior vibration dampening effect, and various spring tensions can be used according to payload.
Characteris Tic: Soft Start
Rating Voltage:DC4.8~7.4V
Temperature Range:-20℃~60℃(-20°~140℉)
Operating Range:540°(1000~2000us)
Broadband Systems:1500μs
Stall Torque:15kg.cm(4.8V)
Stall Torque:18kg.cm(6V)
Stall Torque:20kg.cm(7.4V)
Motion Speed:0.15sec/60°(4.8V)
Motion Speed:0. 13sec/60°(6V)
Motion Speed:0.11sec/60°(7.4V)
Dimension:40.1x20.1x20.7mm
Weight:66g
Specification(GS850 CONTROLLER) :
Rating Voltage:DC4.8~8.4V
Temperature Range:-20°C~65°C (-4°~140°F )
Operating Current Consumption:55mA@ 6V(ROLL)
Operating Current Consumption:40mA@ 6V(PAN)
Maximum Control range:(ROLL) ±30°
Maximum Control range:(PAN) ±90°
Maximum Control range:(TILT) ±90°
Maximum Control rotation Speed:(ROLL) 60°/ s
Maximum Control rotation Speed:(PAN) 150°/ s
Maximum Control rotation Speed:(TILT) 150°/ s
Dimension:42.7x 30 x 14.2mm
Weight:11g
Specification(T-REX 800E DFC) : Accessories:
Features:
●Gimbal features Fiberglass composite material composite material matched with high strength aluminum alloy to form the backbone, featuring high precision, high stability, high payload capability, and is able to sustain hard landing of helicopter.
●Utilizes 540 degrees DS815 high voltage robotic servos, supporting 2s 7.4v input voltage. Special slow start feature to avoid jerky start-ups.
●New GS850 Controller support with 5 operating modes and various functions as usual, further equipped with built-in PAN, ROLL and TILT gain dials enable immediate attitude compensating reaction based on different weight of photograph equipment. Featuring much higher degree of control precision.
●Simple to setup. Complete setup can be done with two steps.
●Unique rescue mode, to minimize photography equipment damage during a crash.
●Supports lens zoom in and zoom out feature.
●Supports shutter activation. Follow the instruction to connect shutter with GS850 controller, shutter can be activated via transmitter stick through GS850.
●Supports Spektrum/JR satellite receivers and Futaba S.BUS architecture.
●Upgradeable firmwareinterface, allowing firmware updates through interface cable.
●Must be used in conjunction with Align APS gyro and 3GX flybarless system, enabling gimbal control system to achieve high stability and excellent controllability.
Users must have a certain concept of security to operate the R/C helicopters.
Be sure to read and comply with related safety notes of instruction manual before flying.
●G800F Gimbal x 1 set
●G800 Gimbal Support Assembly x 1 set
●G800 Gimbal Accessory x 1 set
●G800 Gimbal Camera Pad x 2 pcs
●GS850 Controller x 1 set
●DS815 HV Robor Servo x 3 set
●ESC Mount x 1 pcs
●G800 Gimbal Shock Absorbers Assembly x 1 set
●G800 Gimbal Shock Accessory x 1 set
This Product was added to our catalog on Saturday, 03. August 2013.
