3D VR Headset, high quality, immersive and exciting 3D viewer.
Humanized and comfortable design also compatible with most iOS and Android smartphone system. Lens made from high visible light transmittance of nano-coating technology, and with 92-98 degree viewing angle allow to bring you in exciting and immersive 3D world. Only need to install/download 3D cardboard in your smartphone, and simply insert your smartphone to start enjoying 3D movie or 3D games.
Focus Shot
Humanized and comfortable design.
Through built-in Gyro in smartphone. Support 3D head-tracking and 360 degree panoramic views.
Perfect compatible with iphone 6S plus. Compatible with smartphone with 4.0-6.0 inch screen.
Focal distance adjustable.
Compatible with most current glasses.
42mm hard resin lens, super clear and without distortion.
Specification
●Dimension: 170x120x105mm
●Weight: 300g
●Lens: 42mm aspheric hard resin lens.
●Deformation / Zoom: 1%~2% / 1.5~2 times
●Cushioning material: High-grade PU + Memory Foam.
●Viewing Angle: 92~98 degree.
●Compatible with smartphone Android/iOS system with 4.0-6.0 inch screen; max size: 6.0 inch (163mm x 83mm).
3D VR
