Top » Home Shop » RC World » Agricultural Drone » Agricultural Drone Batteries » HBP16001
€ 22
Li-Po Battery 6S 16000mAh
HBP16001
€ 238.99
Appearance:
Appearance:
●Suitable for ALIGN E1 PLUS use.
●Max Continuous Discharge: 35C.
NOTE:
●Output:22.2V/16000mAh 355.2Wh(6S1P)
●Support 5C charging.
●Dimension:185x77x68mm
●Weight:2000g
●Max Continuous Discharge:35C
●Amass XT90S-F Fire-Proof Connector
This Product was added to our catalog on Thursday, 06. August 2020.
