Top » Home Shop » RC World » Agricultural Drone » Agricultural Drone Electric Equipment » HEG00016A
€ 187
3S High-pressure Pump(included controller)
HEG00016A
€ 77
Appearance:
●Suitable for ALIGN Agricultural Drone.
●The high-pressure pump is specially designed for agricultural spraying. The internal motor spindle adopts a 3-bearing fixed design, which greatly improves the stability of the pump during operation and effectively extends the service life.
●Enlarged metal motor mount design, structural strength is improved, the spraying pressure of the pump is more constant, and the heat dissipation function of the pump is provided when the pump is running, so that the pump water output can be increased up to 5L/min.
●MOSFET with independent micro drive chip, withstand current 30A, small but support powerful output, fast response 10 times faster than the general MOSFET in the market.
High-pressure Pump:
●Pump Supply Voltage:DC12V
●Pump Power Consumption:5A
●Pump Amount:5L/min
●Pump Max. Operating Pressure:0.5MPa
RCE-BL30A 1P Controller:
●Input Voltage: 12V(3S~4S Li-Po)
●Max. Continuous Current For Each Channel: 30A
●Operating Temperature: -5°C~85°C(23°F~185°F)
Content:
●3S High-pressure Pump x 1
●RCE-BL30A 1P Controller x 1
This Product was added to our catalog on Tuesday, 26. January 2021.
