Focus Shots
Standard Equipment
●ALIGN M4T12 Kits Set x 1 set
●12L Chemical Container x 1
●M6 Motor Power System x 4 set
●High-Performance Remote Control X1
●Millimeter Wave Radar x 1
●Portable 3K Carbon Fiber Battery Mount x 1
Shipping Instructions
Pre-assembled and well-tested in factory.
Packing Dimension
ALIGN M4T12 Product Specification
●Airframe: 1278mm
●Height: 482mm
●Foldable Rotor: 3090(350mm)
●Main Rotor Diameter: 778mm
●Power System: M6 Motor (Max. Tensile Force 15.5kg/set)
●Chemical Container: 12L
●Limited Payload: 10L
●Empty weight: 11.8kg
●Maximum flight weight: 24.9kg
●Max. Working Speed: 20km/H.
●Max. Wind-resistance: force 7 wind
●Flight Time Without Payload:
  Approx. 25 mins. (w/ 16000mAh battery)
●Spray Operation Flight Time:
  Approx. 12 mins. (w/ 16000mAh battery)
Self-provided Equipment
UP600+ Intelligent Charger System (AC 110V or AC 220V) x 2 set
●Main Power Battery 6S Li-Po 16000~22000mAh x 4 pcs (= 2 set) and more
●Main Power 12S Intelligent Battery 16000~22000mAh
ALIGN Flying Simulator for flying practice
ALIGN M4T12 Specification
M6 Motor Power Set Specification
●Recommended Battery:12S (LiPo)
●Sustained Ceiling Current:80A(2sec)
●Max. Tensile Force : 15.5kg/Set (46V)
●Weight:1040g
●Working Environment Temperature : -20~65℃
●Protection Rating : IPX7
●Emission Frequency:24Ghz
●Emission Power ( EIRP ):20 dBm
●Measurement Accuracy:5cm
●Update Rate:94Hz
●Working Temperature:-25℃~85℃
●Dimension:80.7x80.4x15mm(HxWxD)
●Weight:82.8g
