Top » Home Shop » RC World » Agricultural Drone » Agricultural Drone Charger » HEC00008
€ 8
1200W Dual Channel Intelligent Charger
HEC00008
€ 363
Instructions: Specification:
Balance Charger has dual charge management system designed for Align Agricultural Drone, charging either two 6S Li-Po battery or Li-HV battery and storage battery in the meantime. Intelligent and easy to charge at one button.
●Support two sets of battery with 6 cells (LiPo / LiHV).
●Charging 2S/3S battery independently (charging one battery only at one time)
●Charging Current : 5A/10A/15A/20A/25A
●Balance charging mode and storage (maintain) mode.
●Remember last time charging current
●Multiple Protection Functions: Overload Protection, Overcurrent Protection, Reverse Polarity, Temperature Protection
NOTE:
3.Before placing your order, please make sure to confirm local voltage for buying correct input voltage charger to prevent any unexpected danger and fire resulting from wrong voltage input.
4.Keep the charger and battery away from flammable items.
5.Never leave the charger unattended, in case of causing an accident.
6.The battery should be charged under 5-40 degree Celsius environment.
7.Keep the charger away from dust, moist, rain, heat, direct sunshine and vibration.
8.Before you power off the charger, please “stop” the charger first, unplug the battery, then unplug the power cord of the charger.
●AC Input Voltage :100~240V
●Charging Ports :2 ports
●Function:Charge Mode/Storage Mode
●Charging Power :1200W(600W×2)
●Support Battery Type :LiPo Battery/ LiHV Battery
●Battery Cell:6S Battery(Charging 2S/3S battery independently)
●Charing Current :5A/10A/15A/20A/25A
●Discharging Power :80W(40W×2)
●Balanced Current :1.5A/cell
●Output Voltage :DC 7.4~25.2V
●Protection Functions :Overload Protection, Overcurrent Protection, Reverse Polarity, Temperature Protection
●Display :LED Indicator + LCD Intelligent Display
●Size :268x140x127mm
●Weight :3.1kg
Content:
●1200W Dual Channel Intelligent Charger x 1
●Balance Connector x 2
●Charging cable x 2
●power cord x 1
This Product was added to our catalog on Tuesday, 06. June 2023.
