Focus Shots
Specification
●Engine: Gasoline engine 225cc
●Horsepower: 7.5hp
●Engine electric start
●Fuel tank capacity: 1.5L
     (approximately 70 minutes of operation)
●Number of blades:
     5mm High Carbon Steel Blades x 1 set(3 pieces)
●Power generation system: 1500W
●Motor power: 600W
●Battery specifications: 24V 15Ah
●Mowing width: 60cm
●Knives height: remote control lifting
     (No segment adjustment)
●Mowing height: 1.5-10cm
●Working slope: 45°
●Remote control distance: 600-700M(None Obstacles)
●Image resolution: 720P
●Lawn mowing lift: remote control automatic lift
●Track width: 120mm
●Machine size: 109x103x44cm
●Machine weight: 155kg
Accessories
●GA22X Automatic Lawn Mower x 1 set
●A15 Transmitter x 1 set
●Balance Charger(110V) x 1
●Vernier caliper x 1
●Toolkit x 1
Electronic equipment required for assembly
●RTK Mobile Station
ALIGN GM22 & GA45X | Bobcat & Automatic Lawn Mower
ALIGN G45X install the dozer blade
