Top » Home Shop » RC World » Aerial Photography / Mission Drone » Charger/Battery » HBP35001
€ 37
M450/M460 Intelligent  Battery 6S  3500mAh
HBP35001
€ 70
●Suitable for M450 / M460.
●Brand new 3500mAh high efficiency battery. Delicate outfit and all-in-one quick release battery mounting plate. The battery indicator light shows current battery capacity by pressing the power button.
●These high discharge lithium polymer batteries are designed to maintain performance in series configuration, and can be charged individually through balancing plug. The extremely high capacity is catered specifically for applications requiring longest flight duration, Suitable for extreme maneuver flight needed.
NOTE:
●Output:22.2V 3500mAh 77.7Wh (6S1P)
●Support 5C charging.
●Dimension:186x58.9x57.4mm
●Weight:528g
This Product was added to our catalog on Wednesday, 19. February 2025.
