Standard Equipment
●ALIGN E1 V2 Kits Set x 1 set
●900mm Carbon Fiber Blades/3 x 1 set
●115mm Fiber Tail Blades x 1 set
●Main Power - 1000MX Brushless Motor(350KV) x 1
ALIGN E1 V2 KIT Specification
●Body Length:1600mm
●Body Height:560mm
●Body Width:345mm
●Main Rotor Length:900mm
●Main Rotor Diameter:1986mm
●Tail Rotor Diameter:303mm
●Power Motor:MX1000 (350KV)
●Weight(Without Battery):Approx. 7.6kg
●Max. Take-off Weight:24.9kg
Self-provided Equipment
●Balance Charger
●Main Power Battery 6S Li-Po 10000~22000mAh x 2 pcs
●Receiver(6-channel or more)
●Flybarless System
●CCPM Brushless Servo x 3
●Rudder Brushless Servo x 1
●Brushless ESC x 1
