Top » Home Shop » RC World » Aerial Photography / Mission Drone » Charger/Battery » HBP42002
€ 33
M3 Intelligent Battery 6S 4200mAh
HBP42002
€ 95
●Suitable for M3.
●Brand new 4200mAh high efficiency battery. Delicate outfit and all-in-one quick release battery mounting plate. The battery indicator light shows current battery capacity by pressing the power button.
●These high discharge lithium polymer batteries are designed to maintain performance in series configuration, and can be charged individually through balancing plug. The extremely high capacity is catered specifically for applications requiring longest flight duration, Suitable for extreme maneuver flight needed.
NOTE:
●Output:22.2V 3500mAh 93.2Wh (6S1P)
●Support 5C charging.
●Dimension:167x50x51mm
●Weight:560g
This Product was added to our catalog on Tuesday, 28. October 2025.
