Top » Home Shop » RC World » Aerial Photography / Mission Drone » Charger/Battery » HBP48001
€ 97
M3 High Voltage Intelligent Battery 6S 4800mAh
HBP48001
€ 110
●Suitable for M3.
●Brand new 4800mAh high efficiency high voltage battery. Delicate outfit and all-in-one quick release battery mounting plate. The battery indicator light shows current battery capacity by pressing the power button.
●These high discharge lithium polymer batteries are designed to maintain performance in series configuration, and can be charged individually through balancing plug. The extremely high capacity is catered specifically for applications requiring longest flight duration, Suitable for extreme maneuver flight needed.
NOTE:
●Max voltage:26.1V (6S1P)
●Support 5C charging.
●Dimension:167x50x51mm
●Weight:511g
This Product was added to our catalog on Thursday, 20. November 2025.
