Focus Shots
Specification
●Engine: Gasoline Engine, 452 cc
●Horsepower: 16hp
●Engine Start: Electric Start
●Fuel Tank Capacity: 6 L (≈ 1.6 US gal)
     (Approx. 200 minutes of continuous operation)
●Blade: 5 mm High-Carbon Steel Blade x 1 set (≈ 0.20 in thickness)
●Generator Output: 1500W
●Motor Power: 600W (≈ 0.8HP)
●Battery: 24V 30Ah(≈ 720 Wh total capacity)
●Cutting Width: 75 cm (≈ 29.5 in)
●Cutting Height: 3–15 cm
     (≈ 0.8–5.5 in, stepless adjustment)
●Maximum Working Slope: 45°
●Remote Control Range: 200 m (≈ 656 ft)
●Track Width: 120 mm (≈ 4.7 in)
●Overall Dimensions (L x W x H):
      124 x 110 x 52 cm(≈ 48.8 x 43.3 x 20.5 in)
●Machine Weight: 263 kg (≈ 579.8 lb)
Accessories
●GA45SE Automatic Lawn Mower x 1
●Balance Charger(110V) x 1
●A15 Transmitter x 1 set
●Vernier Caliper x 1
●Toolkit x 1
Electronic equipment required for assembly
●RTK Mobile Station
