Top » Home Shop » RC World » Aerial Photography / Mission Drone » Charger/Battery » HBP60003A
€ 173
M460 Intelligent  Battery  6000mAh
HBP60003A
€ 147
●Suitable for M460 / M490.
●Brand new 6000mAh high efficiency battery for 16~20 minutes. Delicate outfit and all-in-one quick release battery mounting plate. The battery indicator light shows current battery capacity by pressing the power button.
●These high discharge lithium polymer batteries are designed to maintain performance in series configuration, and can be charged individually through balancing plug. The extreme high capacity are catered specifically for applications requiring longest flight duration, Suitable for extreme maneuver flight needed.
NOTE:
●Output:22.2V 6000mAh 133.2Wh (6S1P)
●Support 5C charging.
●Dimension:168x52x48mm
●Weight:860g
This Product was added to our catalog on Wednesday, 30. September 2026.
