Focus Shots
Standard Equipment
●ALIGN M4 Kits Set x 1 set
●V32 Transmitter set x 1
●Remote Control Super Bright Headlight x 1
●M4 Motor Power System x 4
(Max. Tensile Force : 19.5 KG/Set)
●17L Chemical Container x 1
ALIGN M4 Product Specification
Body Length: 2,373mm
Body Height: 475mm
Body Width: 2,373
Foldable Rotor: 34 inch
Main Rotor Diameter: 885mm
Power System: M4 Motor (Max. Tensile Force 19.5kg/set)
Max Take Off Weight: 26.2kg
Max. Working Speed: 8M/sec.
Operation Time:
Approx. 6 mins. (w/ 22,000mAh battery)
Self-provided Equipment
●UP600+ Balance Charger (AC 110V or AC 220V) x 2 set
●Main Power Battery 6S Li-Po 16000~22000mAh x 4 pcs (= 2 set) and more
● ALIGN Flying Simulator for flying practice
●8" Tablet
  • * Support Android V8.0 or better.
  • * Considering the best working efficiency, the specifications of the tablet are recommended as follows: 8” Tablet, 6 Core CPU, 3GB RAM, more than 32GB ROM storage space and support 5G Wi-Fi.
  • * The max. dimension of screen bracket is 240 x 169mm.
●Tablet Suggestions:
  Samsung Galaxy Tab A /Model Type:SM-T385
  Samsung Galaxy Tab A 8.0 /Model Type:T295 (LTE)
  Samsung Galaxy P200
  Samsung Galaxy Tab A 10.1 /Model Type:SM-T510
  Mi Band 4
  ASUS ZenPad 3 8.0 /Model Type:Z581KL
ALIGN M6 Specification
M4 Motor Power Set Specification
●Recommended Battery:12S (LiPo)
●Sustained Ceiling Current:120A(2sec)
●Max. Tensile Force : 19.5kg/Set(46V)
●External Diameter:104mm
●KV Value : 110KV
●Weight:1400g
●Working Environment Temperature : -20~55℃
●Protection Rating : IPX7
Flight Safety
