Top » Home Shop » RC World » Helicopter » Heli Parts » 450 Parts » H45162
 RC World
 -   Helicopter
    Helicopters
    Heli Parts
      100 Parts
      150 Parts
      T15 Parts
      250 Parts
      300X Parts
      450 Parts
      450L Parts
      TB40 Parts
      470L Parts
      500L Parts
      500X Parts
      550E Parts
      550L Parts
      550X Parts
      TB60 Parts
      600L Parts
      600 Nitro Parts
      600XN Parts
      650 Parts
      700E Parts
      TB70 Parts
      700X Parts
      TN70 Nitro Parts
      700 Nitro Parts
      700XN Parts
      760 Parts
      800E Part
      E1 900 Parts
      Three Blade
    Helicopter Motor
    Helicopter Main Blade
    Helicopter Tail Blade
    Helicopter Fuselage
    Heli Canopy
    Helicopter Electric Equipment
    Brushless ESC
    Servo
    Charger/Batteries
    Bearing
    Helicopter Screw Parts
 -   Mission Helicopter
 -   Agricultural Helicopter
 -   Agricultural Drone
 -   Lawn Mower
 -   DJI植保無人機
 -   Racing Drone
 -   Control Radio
 -   Flying Simulator
 -   RC Articles
 Vacuum Cleaner
 Milling Machine Equipment
US$ 2,105
450DFC Main Rotor Head Upgrade Set
H45162
US$ 53.99
Product illustration:
Appearance:
Appearance:
Appearance:
Instruction:
●Follow by 700 DFC/600 DFC's design, the 450 DFC flybarless rotor head system utilizes extreme low CG design, effectively reduces resistance during flight, increased flight responsiveness and precision, resulting in superior 3D performance and unimaginable flight speed with extremely attractive design.
Features:
●Extreme low CG and short main shaft design, dramatically reduces flight resistance, effectively improves T-Rex 450's 3D performance and speed.
●New style linkage rod design, complete assembly increases linkage rod rigidity, allowing the pitch slider (follower) to be omitted, resulting in a head assembly that is much simplified and rigid.
●Upgrading to the 450DFC rotor head assembly is extremely easy; just replace the head block included in the 450DFC kit, connect the 450DFC linkage assembly, and replace the main shaft with 450DFC main shaft. Existing swashplate is kept in the upgrade.
●The damper rubbers are manufactured utilizing POM material, sleek surface, with superior anti-wear characteristic.
●Suitable for all T-REX 450 Pro/Sport V2 flybarless system Use 450 SE/SPORT must purchase additional dedicated Main Shaft Set- H45H001XXW
●450DFC Main Rotor Head Assembly x 1
●450DFC Main Blade Grip x 2
●84ZZ Bearing x 4
●450DFC Damper rubber x 2 (POM Φ4xΦ6.5x3.8mm)
●Spacer × 2
●Socket collar screw(M2x12mm) x 1
●M2 Nut × 1
●M2 collar screw(M2x15mm) x 2
●450DFC Main rotor grip arm integrated control link x 2
●450DFC Main rotor grip linkage bearing sleeve x 2
●681ZZ-d2 Bearing(Φ2x4.5x2mm) x 4
●450DFC Linkage rod A x 2
●Ball link × 2
●450DFC Main Shaft x 1
●Socket collar screw × 2(M3x16mm)
●M3 Nut × 2(M3)
●Main shaft spacer × 1(Φ5×Φ9×0.1mm)
●Main shaft spacer × 1(Φ5×Φ9×0.2mm)
