Top » Home Shop » RC World » Helicopter » Charger/Batteries » Batteries » HBP13002
US$ 200
Li-Po Battery 3S 1300mAh
HBP13002
US$ 14.99
Appearance:
●Suitable for T-REX 300X series.
●This Li-poly battery features high efficient and high discharge, use a inspection machine to match packs, suitable for other professional model airplanes, cars, and guns.
●Max Continuous Discharge: 30C(39A).
NOTE:
●Output: 11.1V 1300mAh 14.4Wh(3S1P)
●Support 5C charging.
●Dimension: 70x29x21mm
●Weight: 99g
●Amass XT30U-F Connector
This Product was added to our catalog on Tuesday, 13. August 2019.
