Top » Home Shop » RC World » Helicopter » Charger/Batteries » Batteries » HBP15004
€ 1,160
Li-Po Battery 4S 1500mAh
HBP15004
€ 25.99
●Suitable for MR25 series.
●This Li-poly battery features high efficient and high discharge, use a inspection machine to match packs, suitable for other professional model airplanes, cars, and guns.
●Max Continuous Discharge: 40C(60A).
NOTE:
●Output: 14.8V 1500mAh 22.2Wh(4S1P)
●Support 3C charging.
●Dimension: 88x35x28mm
●Weight: 160g
●Amass XT60-F Connector
This Product was added to our catalog on Thursday, 30. June 2016.
