Top » Home Shop » RC World » Aerial Photography / Mission Drone » Battery » HBP52004
US$ 1,245
Li-Po Battery 6S 5200mAh
HBP52004
US$ 151.99
Appearance:
●Suitable for TB70 / T-REX 550~T-REX 800.
●These high discharge lithium polymer batteries are designed to maintain performance in series configuration, and can be charged individually through balancing plug. The extreme high capacity are catered specifically for applications requiring longest flight duration, Suitable for extreme maneuver flight needed.
●Max Continuous Discharge: 60C.
NOTE:
●Output:22.2V 5200mAh 115Wh (6S1P)
●Support 5C charging.
●Dimension:138x42x60mm
●Weight:780g(Including connectors)
●Max Continuous Discharge:60C
●Using 10AWG wire,thermal resistance:200°C, max continuous current 140A.
●Amass XT60-F Connector
This Product was added to our catalog on Wednesday, 15. January 2014.
