Top » Home Shop » RC World » Helicopter » Heli Parts » 700 Nitro Parts » HN7091
 RC World
 -   Helicopter
    Helicopters
    Heli Parts
      100 Parts
      150 Parts
      T15 Parts
      250 Parts
      300X Parts
      450 Parts
      450L Parts
      TB40 Parts
      470L Parts
      500L Parts
      500X Parts
      550E Parts
      550L Parts
      550X Parts
      TB60 Parts
      600L Parts
      600 Nitro Parts
      600XN Parts
      650 Parts
      700E Parts
      TB70 Parts
      700X Parts
      TN70 Nitro Parts
      700 Nitro Parts
      700XN Parts
      760 Parts
      800E Part
      E1 900 Parts
      Three Blade
    Helicopter Motor
    Helicopter Main Blade
    Helicopter Tail Blade
    Helicopter Fuselage
    Heli Canopy
    Helicopter Electric Equipment
    Brushless ESC
    Servo
    Charger/Batteries
    Bearing
    Helicopter Screw Parts
 -   Mission Helicopter
 -   Agricultural Helicopter
 -   Agricultural Drone
 -   Lawn Mower
 -   DJI植保無人機
 -   Racing Drone
 -   Control Radio
 -   Flying Simulator
 -   RC Articles
 Vacuum Cleaner
 Milling Machine Equipment
US$ 0.8
Main Rotor Set Limited Edition
HN7091
US$ 233.99
Appearance:(Metal Main Rotor Holder)
Appearance:(Metal Head Stopper)
Appearance:(Metal Main Rotor Housing)
Appearance:(Metal SF Mixing Arm)
Appearance:(Metal Flybar Seesaw Holder)
Appearance:(Metal Washout Control Arm)
Appearance:(Metal Flybar Control Arm)
Appearance:(CCPM Metal Swashplate)
Appearance:(Feathering Shaft)
Appearance:(Main Blade Linkage Rod)
Appearance:(Metal Washout Base)
Instructions: Specification:
●6061-T6 Aluminum alloy material and CNC processed。
●Suitable for T-REX 700 Nitro
●Metal main rotor housing set x 1
●Metal head stopper x 1
●Linkage ball A(M4x5) x 2
●Linkage ball B(M3x4) x 9
●Linkage ballC(M3x3.5) x 4
●Metal main rotor holder x 2
●Bearing 683ZZ x 8
●Bearing MR104ZZ x 2
●Bearing MF105ZZ x 2
●Bearing FMR52ZZ x 4
●Bearing 6800ZZ x 2
●Bearing 6706ZZ x 2
●Thrust bearing F10-18M x 2
●Collar x 4
●Feathering shaft x 1
●Feathering shaft collar screw x 2
●Pin x 2
●Fastening rod x 1
●Washer x 8
●Socket screw x 4(M2x5mm)
●Socket screw x 2(M4x8mm)
●Socket screw x 1(M3x10mm)
●Socket screw x 4(M3x5mm)
●Socket screw x 4(M3x6mm)
●Socket button head screw x 4(M3x12mm)
●Flybar control rod x 2
●M4 Nut x 1
●M5 Nut x 2
●Metal flybar seesaw holder x 1
●Socket collar screw x 2(M5x32mm)
●Feathering shaft sleeve x1
●Spacer x2
●Metal SF Mixing arm x 2
●Metal washout control arm x 2
●Metal flybar control arm x 2
●Radius arm x 2
●M4 collar screw x 2
●Socket collar screw x 1(M4x24mm)
●Metal washout base x 1
●CCPM Metal Swashplate x 1
●Metal cover x 1
●Metal stand x 1
●Grommet x 2
●Ball bearing x 1
●M4 Set screw x 2
●700N Washer
●700N Feathering shaft sleeve
●700N Damper rubber
● Linkage rod A x 2
● Linkage rod B x 2
● Linkage rod C1 x 2
● Linkage rod x 12
This Product was added to our catalog on Friday, 13. November 2009.
