Top » Home Shop » RC World » Helicopter » Brushless ESC » Brushless ESC » K10476A
US$ 143
Brushless ESC Cooler Plate
K10476A
US$ 7.99
Step 1:Cut open the existing heat shrink tubing. If there are heatsinks on both sides of the ESC, first remove the heatsink on the flat heat dissipation plate, then remove the dust insulators on both sides of the ESC Step 2:Heat transfer compound at the back side of the cooler plate already,Using a hobby knife as shown in the photo, spread the thermal grease evenly on the back of the heatsink
Step 3:Attach the heatsink to the flat heat dissipation plate Step 4:To avoid short circuit of the ESC, care must be taken to position the heatsink exactly as shown in the diagram
Step 5:Slide the included heat shrink tube on to both sides Step 6:Apply heat using heat gun or lighter to shrink the heat shrink tubing
Instructions: Specification:
●Apply for RCE-BL60G/70G/75G/100G Brushless ESC.
●High efficiency large surface area heatsink for ESC, to improve motor and BEC maximum output current by 15%.
●ESC cooler plate x 1(48x31x16mm)
●Heat shrink tube x 2(Φ28x10mm)
●Weight:15.4g
This Product was added to our catalog on Monday, 05. July 2010.
