Top » Home Shop » RC World » Helicopter » Heli Parts » 700E Parts » HN7114A
 RC World
 -   Helicopter
    Helicopters
    Heli Parts
      100 Parts
      150 Parts
      T15 Parts
      250 Parts
      300X Parts
      450 Parts
      450L Parts
      TB40 Parts
      470L Parts
      500L Parts
      500X Parts
      550E Parts
      550L Parts
      550X Parts
      TB60 Parts
      600L Parts
      600 Nitro Parts
      600XN Parts
      650 Parts
      700E Parts
      TB70 Parts
      700X Parts
      TN70 Nitro Parts
      700 Nitro Parts
      700XN Parts
      760 Parts
      800E Part
      E1 900 Parts
      Three Blade
    Helicopter Motor
    Helicopter Main Blade
    Helicopter Tail Blade
    Helicopter Fuselage
    Heli Canopy
    Helicopter Electric Equipment
    Brushless ESC
    Servo
    Charger/Batteries
    Bearing
    Helicopter Screw Parts
 -   Mission Helicopter
 -   Agricultural Helicopter
 -   Agricultural Drone
 -   Lawn Mower
 -   DJI植保無人機
 -   Racing Drone
 -   Control Radio
 -   Flying Simulator
 -   RC Articles
 Vacuum Cleaner
 Milling Machine Equipment
US$ 9
700 New Designed Main Rotor Head Assembly
HN7114A
US$ 176.99
Appearance:(Metal Main Rotor Holder)
Appearance:(Metal Head Stopper)
Appearance:(Metal Main Rotor Housing)
Appearance:(Flybar seesaw holder set)
Appearance:(Metal SF Mixing Arm)
●6061-T6 Aluminum alloy material and CNC processed。
●This newly designed 700 class head assembly upgrade was introduced to fulfill the needs of helicopter modification enthusiasts. With multiple linkage mounting holes, this head is capable of 3 sets of positive and negative deltas, numerous Bell & Hiller mixing ratios, along with various Flybar Effectiveness.
●F3C and beginner pilots will benefit from the head’s higher control resolution as well as stability level, satisfying the need of both highly stable static categories as well as precision aerobatic categories.
●For 3D pilots who prefer the explosive agility characteristics, the new head allows for increased collective and cyclic response. Fast tic-toc and other demanding maneuvers can be tackled easily.
●In addition to the high adjustability, the rigidity of this head is also improved, with specially treated exterior resulting in extraordinary presentation. This head would definitely satisfy enthusiasts seeking the latest cutting edge equipment.
●Suitable for T-REX 700E / 700N / 700F3C
●700 New Designed Main Rotor Head Assembly x 1
●MF95ZZ Bearings(ψ5xψ9x2.4mm) x 2
●700N Feathering shaft sleeve(ψ10.2xψ17x21mm) x 2
●700 Damper rubber-紅(ψ9.9xψ17x7mm) x 2
●700 Damper rubber(ψ9.9xψ17x7mm) x 2
●Socket screw(M4x24mm) x 1
●Socket screw(M4x8mm) x 2
●Metal main rotor holder(72x54x18mm) x 2
●6800ZZ Bearing(ψ10xψ19x5mm) x 4
●700 Main Blade Grip Arm x 2
●683ZZ Bearing(ψ3xψ7x3mm) x 4
●Collar(ψ3xψ4.8x1.5mm) x 2
●Washer(ψ3xψ4.8x0.3mm) x 4
●Thrust bearing F10-18M x 2
●700N Spindle bearing spacer(ψ10xψ16x1mm) x 4
●700N Linkage ball C(M3x3.5) x 4
●Socket screw(M3x6mm) x 4
●Socket screw(M3x12mm) x 2
●Socket screw(M5x32mm) x 2
●700N Flybar control rod(ψ5xψ4.5x71mm) x 2
●M4 Set screw(M4x4mm) x 2
●700 Metal flybar control arm(中心54x17.5x9mm) x 2
●Socket screw(M3×6mm) x 4
●700N Feathering shaft(φ7xφ10x106.50mm) x 1
●700N Collar screw(M6x16mm) x 2
●700 Flybar seesaw holder(69x11.3x11mm) x 1
●M3 Collar screw(M3x9.3mm) x 2
●MR104ZZ Bearing(ψ4xψ10x4mm) x 2
●Linkage ball A(M3x3) x 2
●Linkage rod A(ψ1.96x14mm) x 2
●700N Linkage rod B(ψ1.96x22mm) x 2
●700 Linkage ball D(ψ2.5x84.5mm) x 2
●700 Metal flybar control arm(59x7.5mm) x 2
●700N Radius Linkage ball x 2
●FMR52ZZ Bearings(ψ2xψ5x2.3mm) x 4
●Socket screw(M2x5mm) x 4
●700N Linkage rod B(M3x4) x 2
This Product was added to our catalog on Thursday, 28. July 2011.
