Top » Home Shop » RC World » Helicopter » Servo » High Voltage Servo » HSL75001
US$ 4
BL750H High Voltage Brushless Servo
HSL75001
US$ 176.99
● Rudder servo with .0.032sec/60° ultra high speed response, pushing the extreme.
● Utilizes brushless motor design for fast speed, high efficiency. And with the absence of brush wear, the longevity of servo is greatly increased.
● Supports 7.4v high voltage to provide optimal speed and torque performance of the brushless servo.
● Designed specifically for helicopters, with highest specifications on the market: 0.032sec/60°ultra fast speed and 7kg-cm monstrous torque, allowing helicopter to perform with faster and higher precision.
● Ultra high 12 bits signal resolution for excellent precision and smoothness.
● Hardened high strength superalloy gears that increase the lifetime.
● Aluminum alloy mid case construction for instantaneous heat dissipation, maintaining servo’s high efficiency.
● Supports both analog and digital control signals.
● Suitable for T-Rex 550/600/700/800 rudder use.
●Stall torque:5.0kg.cm(6.0V)
                   7.0kg.cm(7.4V)
●Motion speed:0.045sec/60°(6.0V)
                     0.032sec/60°(7.4V)
●Rating voltage:DC 4.8-7.4V
●Dimension:40.3 x 20.1 x 38.7mm
●Weight:66g
●1520μs standard band
●Servo rudder piece x 3
●Set screw x 1
●Rubber damper x 4
●Brass grommet x 4
●Tapping screw for servo x 4
