Top » Home Shop » RC World » Helicopter » Helicopter Motor » Brushless Motor » HML80M04
US$ 73.99
800MX Brushless Motor(440KV/4530)
HML80M04
US$ 230.99
Drawing:
Specification Drawing:
Wiring Schematic Drawing:
Instructions: Specification:
●To meet the power and torque requirements of enthusiasts, the high output 800MX motor was born in Align’s R&D lab. With dramatic increase in torque and power output, capable of 4440 watts continuous power output and 8800 watts of burst power!
● 800MX features high efficiency, superior power, excellent torque, low current draw and low temperature; it’s capable of maintaining consistent torque and head speed through continuous F3C maneuvers..
●Due to the 800MX’s high efficiency and low current draw, the standard equipment 130A electronic speed controller are sufficient to experience the power of this motor, and extend battery longevity.
●800MX motor incorporates radial fan in its end bell, creating powerful airflow to dissipate heat. Tweaks to motor design and reduction in weight not only contributes to dramatic power increase, the high efficiency cooling system enables cooler operating temperature during and after flights when compared to motor of previous generation.
●The 800MX motor armature are dynamically balanced to eliminate typical imbalance found in other outrunner motors.
●Maintenance free、high torque、high efficiency、stable, and low noise.
●Suitable For T-REX 650X/700E/800E F3C.
800MX Brushless Motor usage notices
Instruction for setting the ICE2 HV 120 governor mode with 800MX
●Input Voltage:12S
●Max Continuous Current: 100A/200A(2sec)
●Max Output Power: 4440W/8800W(2sec)
●KV Value: 440KV
●Stator Arms: 12
●Magnet Poles: 10
●Dimension: Spindle 6x56.7x94.5mm
●Weight: 508g
●Socket screw(M4x10)x4
●Washer(Φ4xΦ10x1)x4
●4mm gilt terminal x 3
This Product was added to our catalog on Tuesday, 13. October 2020.
