Top » Home Shop » RC World » Helicopter » Servo » Digital Servo » HSD41601
US$ 18
DS416M Digital Servo
HSD41601
US$ 26.99
●Faster speed with high torque performance, allowing helicopter to perform with faster and higher precision.
●High rigidity, shock resistant metal gears with high strength composite alloy gears with durable structure characteristics.
●Powerful and precise servo, suitable for T-Rex 250/450 CCPM cyclic use.
●Stall torque:2.1kg.cm(4.8V)
●Stall torque:2.7kg.cm(6.0V)
●Motion speed:0.1sec/60°(4.8V)
●Motion speed:0.08sec/60°(6.0V)
●Rating voltage:DC 4.8-6.0V
●Dimension:22.9 x 12 x 25.8mm
●Weight:15g
●1520μs standard band
●Servo rudder piece x 2
●Set screw x 1
●Tapping screw for servo x 2
This Product was added to our catalog on Monday, 07. October 2013.
