The new MR25X/MR25XP is born to achieve the ultimate flight performance. Lots of breakthrough designs are being made in its detail structure. Utilize with the latest spilt-type 30A BL-HeliS ESC highly fasten the response and improve effectiveness in flights.
The new MR25X/MR25XP is also equipped the new upgraded 2K DV camera especially for FPV real-time flight, clear and instant. The motor is also upgraded to 2205 2400KV giving sustained power output.
New generation MRS flight controller utilizes a 32 bits high speed processor, combining ESC, power distribution system, OSD, Bluetooth connectivity, and gimbal control function. Featuring a high precision 6-axis gyroscope sensor. Derived from Align's core technology, the highly intelligent attitude calculation subroutine results in a highly stable and reliable performance.
The Acro Pro competitive mode is also uniquely design to satisfy extreme 3D flight pilots, providing model with steering, sensitivity, speed and response three times more than original setting value. Much agile and sensitive reaction, super speed just like feel in a sports car.
Utilize the high-quality camera lens, high video quality more clear and sharp. The lens angle with 120 degree allow to have wider field vision.
Split-type main board with separate ESC from main board makes maintenance easy and convenient. This allows you to change only the ESC if necessary and not the whole main board.
Adopt for 30A ESC with higher withstand current supporting much powerful output.
Supported with oneshot125 control signal function allow to make motor reaction much precise and faster. Also with excellent ESC power control algorithm and motor brake function, which allow to make motor speed control to be more precise and much delicate for more reliable and faster flight performance.
Manual Mode, Sport 3D Mode, Attitude Mode, Acro PRO
Acro PRO - Exclusively design to satisfy extreme 3D flight pilots, the Acro Pro mode provide model with steering, sensitivity, speed and response three times more than original setting value. Much agile and sensitive reaction, super speed just like feel in a sports car.
Manages signal and power distribution. Using a single battery, power is distributed to the flight control, motors, DVR, 5.8Ghz video downlink, gimbal, and multifunction panel. A single master power switch to make powering up simple, and a battery meter to display current battery capacity. The multifunction panel has a unique brake and turn signals for added realism during FPV racing.
High intensity LED's located on bottom, motor mounts, and black plate. The RGB color is customizable using the MRS APP.
Brand new Align BL2205-2400KV multirotor race motor, based on Align's legendary motor core technology, suitable for a 3S/4S battery, featuring high torque, high speed, high efficiency, low power consumption, and low temperature.
2K DV is Advanced FPV camera. Optimization of high-speed flight FPV, the video return image near-zero latency real-time video. Improved low-light process and reduces the contrast of light and shade change, also enhance to 2K video quality, make you feel top-flight experience. Only need the smartphone App, simple steps to complete the camera photograph and video settings easily.
Single axis camera gimbal to provide camera tilting angle compensation during high speed flights, keeping camera image level with horizon. Tilting angle is also manually adjustable.
The new protective servo arm features in smart and optimized anti-collision design allow to protect the server, server gears and DV camera effectively, also it can highly strengthen the intensity of server gear from stripping gears, and extend the usage time of servo.
Live Flight data display including flight time, mode, attitude, voltage, capacity, current, camera mode, recording mode, and low voltage warning.
●Light, tiny and durable material.
●Long term, low-level noise.
●40 Switch Options including Raceband frequency allow to reduce signal interference in competitions.
●Support 25mW ~ 600mW power output.
●Easy to operate : Single easy-switch button and LED indicator.
●Compatible with vary receiver frequencies and FPV racing models.
●Memory Function : Recording previous flight channel and frequency in memory.
●Built-in microphone.
●Support 5V power output for FPV camera.
Superior crashworthiness and impact resistance can effectively protect main control board from damage. An enlarged battery bay allows the use of a larger capacity 4S battery.
Based on personal preference the landing skids can be removed and replaced with buffer PE foam to increase the impact resistance while landing. Also removal of the landing skid can reduce vibration during flinght caused by wind resistance.
Setup and flight parameter tuning can be done through apps running on iOS/Android smart phone or tablets. In addition, the app can be used to control DV camera and video recordings. Bluetooth 4.0 compatibility featuring low power long distance high speed transmission.
MRS Flight Control
●Input Voltage: 10V~16.8V
●Operating Frequency: 800HZ
●Operating Temperature: -20°C~65°C(-4°F~149°F)
●Maximum Angular Speed: Aileron/Elevator 400°/sec, Rudder 45°/sec
●Maximum Tilting Angle: 80 degrees
BLHeli S ESC
●Input Voltage: 11.1V~14.8V(3S~4S Li-Po)
●Max Continuous Current: 30A
●Operating Temperature: -5°C~45°C(23°F~113°F)
RCM-BL2205 Brushless Motor 2400KV(RPM/V)
●Max Continuous Current(3 min): 16.3A
●Max Continuous Power(3 min): 240W
●Stator Arms: 12
●Magnet Poles: 14
●Dimesion/Weight: Φ5xΦ28x25.7mm/25.7g
5.8GHz Video Transmitter
●Operating Frequency: 5.8GHz
●Operating Channels: 40 CH
●Input Voltage: 7~20V DC
●Operating Current: 100mA 12V(25mW), 300mA 12V(600mW)
●Antenna Interface: RP SMA
●Transmitting Power: 25mW ~ 600mW
●Dimesion: 34x25x12mm
●Weight: 10.6g(Exclude Antenna)/28.08g(Include Antenna)
Video Camera
●Recording: 1440P 30FPS / 1080P 60FPS / 1080P 30FPS / 720P 60FPS
●Encoding Format: mov
●Photo Resolution: 4352x3264 pixels
●Shutter speed: 2~1/8000sec
●Input Voltage: 5V
●Aperture: F2.1
●FOV: 90°
●Memory Cards: Micro SD(Maximum Supported 32GB)
●Interface: Micro USB、AV OUT/DV IN、MRS Controller
●Video Output Format: PAL、NTSC
Standard Equipment
● MRS Flight Control System x 1
● Brushless Motor BL2205(2400KV) x 4
● 5.8GHz Video Transmitter x 1
● Circular Polarized Antenna TX x 1
● Circular Polarized Gain Antenna TX x 1
● 2K DV Camera x 1
Specification
● AirFrame Diameter: 250mm
● AirFrame Height(Excluding Antenna): 78mm
● Propeller Diameter: 5040 Tri-Blades / 5040 Propeller
● AUW(Excludes Battery): Approx.390g
Radio Transmitter and Electronic Equipment Required
●R/C Transmitter(6-channel or more,aircraft / multicopter system)
●Receiver(6 channel or more)
●Satellites Receiver
●Balance Charger RCC-3SX
●1300~1800mAh Li-polymer Battery 3S/4S
●5.8G to 2.4G Converter
●Smartphone
●FPV Goggle
●FPV Monitor
Optional Equipment
●MR25XP Racing Quad x 1
●5040 Propeller x 4
●5040 Tri-Blades x 4
●Brushless Motor BL2205 x 4
●Circular Ploarized Antenna TX x 1
●Circular Ploarized Gain Antenna TX x 1
●MR25 Parts Pack x 1
MRS Download
Manual
