Top » Home Shop » RC World » Helicopter » Heli Parts » 150 Parts » HEG15005
 RC World
 -   Helicopter
    Helicopters
    Heli Parts
      100 Parts
      150 Parts
      T15 Parts
      250 Parts
      300X Parts
      450 Parts
      450L Parts
      TB40 Parts
      470L Parts
      500L Parts
      500X Parts
      550E Parts
      550L Parts
      550X Parts
      TB60 Parts
      600L Parts
      600 Nitro Parts
      600XN Parts
      650 Parts
      700E Parts
      TB70 Parts
      700X Parts
      TN70 Nitro Parts
      700 Nitro Parts
      700XN Parts
      760 Parts
      800E Part
      E1 900 Parts
      Three Blade
    Helicopter Motor
    Helicopter Main Blade
    Helicopter Tail Blade
    Helicopter Fuselage
    Heli Canopy
    Helicopter Electric Equipment
    Brushless ESC
    Servo
    Charger/Batteries
    Bearing
    Helicopter Screw Parts
 -   Mission Helicopter
 -   Agricultural Helicopter
 -   Agricultural Drone
 -   Lawn Mower
 -   DJI植保無人機
 -   Racing Drone
 -   Control Radio
 -   Flying Simulator
 -   RC Articles
 Vacuum Cleaner
 Milling Machine Equipment
US$ 36
150GRSA Flybarless System Set(A.BUS)
HEG15005
US$ 74.99
●Use for T-REX 150/150X.
●6-axis Gyro:3-axis gyroscope + 3-axis accelerometer using a superior ARM Cortex-M4 32-bits processor. 3D feeling is superior while auto-level ability is also agile and stable.
●Attitude Auto-level Mode:While there is no stick input for helicopter, the heli will auto-level and still keep at horizontal position, which is suitable for beginners.
●Rescue Mode:While wrong stick input is given or heli is in trouble, or you are in panic, activate the rescue mode by flipping a switch on the radio to keep helis at a level position.
●3D Flying:Brand new DFCS(Direct Flight Control System)Contorller allows to control real time flight. Strong Cortex-M4 Processor allows T-REX 150 to fly just like big scale helicopters.
●Built-in Receiver:ALIGN A.BUS.
●Plug-in Receiver(Required):Compatible with Spektrum DSM2/DSMX, JR DSM2/DMSS satellite
150GRSA Flybarless System:
●Operating voltage range:5V-8.4V
●Operating current consumption: <100mA @ 5V
●Rotational detection rate: 2000°/sec
●Rudder yaw detection rate: 2000°/sec
●Sensor resolution:16BIT
●Operating temperature:-20℃ ~ 65℃
●Operating humidity:0% ~ 95%
●Swashplate Support : MODE H-1
●Receiver Support : ALIGN A.BUS / DSM2 / DSMX / DMSS
●Transmit Distance: In open space without interference <150M
150X Brushless ESC:
●Main motor output current: Continuous 6A / Surge 7A
●Tail motor output current: Continuous 3A / Surge 3.5A
●BEC output current: Continuous 5V/2A / Surge 5V/2.5A
●Persistent maximum current require optimal heat dissipation condition.
●Supported motor types: 2 poles to 18 poles brushless outrunners.
●Maximum rotational speed: 2 poles-240000 RPM, 12 poles-40000 RPM.
●Input voltage: 2S Li-Po.
●150 Main Control Board x 1
●A.BUS Receiver x 1
●7A Brushless ESC x 1
●150 GRS Double Sided Tape A x 1
●150 GRS Double Sided Tape B x 1
●150 Battery Socket x 1
●150 Battery Socket Mount x 1
This Product was added to our catalog on Wednesday, 20. June 2018.
