Top » Home Shop » RC World » Helicopter » Charger/Batteries » Recharger » HEC10002
US$ 53
100W Single Channel Intelligent Charger
HEC10002
US$ 89.99
Instructions: Specification:
Provided maximum power of 100W charge, significantly reducing charging time. With 4 function buttons for easy operation and LCD display, the battery charging status can be monitored in the charging process at any time.
●LiHV Battery
●Program Data Save / Load
●End Voltage Controlled
●Storage Charge
●Maximum Safety
●Capacity Statistic
●Discharge
●Delta Peak Sensitive
●Nixx Battery Cycles
●Battery Meter
●Safety Timer
●Temperature Sensor
NOTE:
●AC input voltage: 100-240V
●DC input voltage: 11-18V
●Charge power: Max. 100W
●Charge current: 10A
●Discharge power: Max. 5W
●Discharge current: 2A
●LiPo/Li-lon/ Life battery cell count: 1-6S
●NiMH/NiCd battery cell count: 1-15cells
●Pb battery voltage: 2-24V
●Dimension: 130x115x61mm
●Weight: Approx. 380g
●100W Single Channel Intelligent Charger x 1
●Power Cord x 1
●Car Battery Charger Cable x 1
●XT60 Male Wire Set x 1
●Balance Charging Cable x 1
This Product was added to our catalog on Monday, 03. December 2018.
