Top » Home Shop » RC World » Helicopter » Charger/Batteries » Batteries » HBP85003
US$ 11
Li-Po Battery 3S 850mAh
HBP85003
US$ 12.99
Appearance:
●suitable for T-REX 250 series.
●This Li-poly battery features high efficient and high discharge, use a inspection machine to match packs, suitable for other professional model airplanes, cars, and guns.
●Max Continuous Discharge: 50C.
NOTE:
●Output:11.1V 850mAh 9.4Wh (3S1P)
●Support 5C charging
●Dimension:55x30x24.5mm
●Weight: 70g
●JST-F Connector
This Product was added to our catalog on Thursday, 13. December 2018.
