Top » Home Shop » RC World » Helicopter » Charger/Batteries » Batteries » HBP12001
US$ 2,140
Li-Po Battery 6S 12000mAh
HBP12001
US$ 223.99
Appearance:
Appearance:
●Suitable for ALIGN E1 use.
●Max Continuous Discharge: 30C.
NOTE:
●Output:22.2V/12000mAh 266.4Wh(6S1P)
●Support 5C charging.
●Dimension:190x74x60mm
●Weight:1700g
●Max Continuous Discharge:30C
●Amass XT90S-F Fire-Proof Connector
This Product was added to our catalog on Friday, 08. November 2019.
