Brand New ALIGN E1 PLUS Agricultural Helicopter!
The battery compartment accommodate 80mm x 70mm large-capacity batteries, so the flight time can be reached up to 20.5 mins with 12S 44.4V 16000mAh (6S1Px2) battery, which provides stability for high-load operations , sufficient power performance, and improve work efficiency. In addition, the three-section canopy design can make easy for battery replacement and provides better protection for the body. In terms of function, it has also improved to a higher level. In addition to optimizing the existing functions, it also provides new functions such as the latest AB+ automatic navigation mode.
●Longer Flight Time Up To 20.5 Minute (16000mAh)
●Obstacle Avoidance Radar
●Headlight Remote Control
●Adjustable Up and Down HD Image
●High Wear Resistance Torque Tube Drive Gear
●High Endurance and Efficiently Save Power 15%
●High Pressure 6 Nozzles with Large Spraying at 4L/min
●Newly High Stable Auto Flight Control System
Win the 26th Taiwan Excellence Silver Award! ALIGN E1 Agricultural Helicopter is revolutionizing the way agriculture is done. It’s an advanced helicopter for modern green farming and spraying that can be competed up to 0.48 acres per minute; 30 times faster than traditional machinery. Specially inherit “Helicopter” body design, when it rotates, the strong airflow will carry the spraying directly down to the whole plant leaves and roots reducing the loss cost of spraying.
ALIGN E1 is designed with composite material and 3K Carbon Fiber that is lightweight but extremely durable. Besides, it features well water proof, rust proof and oxidation proof also high quality finish. It’s capable of switching the 15KG chemical containers in 5 seconds reducing the risk of being dangers of exposing ourselves to the pesticide. There are two types of fan-shaped nozzles can be used for adjusting output to different plants.
ALIGN E1 adopt sonar altimeter to detect the terrain height so the helicopter can adjust to maintain the same distance from the plants to provide a uniform spray across all crops. Also it has built-in triple sensor positioning module with GPS, Glonass and BDS system providing precise, stable and real-time positioning. Moreover, it’s compatible with P2 PCU (Power Control Unit) allow to distribute and integrate the power supply safely.
Align AP2 intelligent flight controller has built-in ARM Cortex-M4 32 bits 180MHz processor supports multiple flight modes (such as Attitude/GPS/Intelligent), Auto Return Home and Rescue Return Home, Low Voltage Protection, OSD output and Gimbal Control. Moreover, in our highly integrated ground station, the automated mapping function will compute the best spraying route for you or allow you to map preferred pattern. Other ground station functions like Optical Radar Terrain Detection System, Altitude Positioning, Equipped Video and Spray System Monitoring can also achieve advanced spray capacity for safe, efficient and convenient way to deliver superior crop protection.
Focus Shots
Shipping Instructions
Pre-assembled and well-tested in factory.
Packing Dimension
Standard Equipment
●ALIGN E1 Kits Set x 1 set
●830mm Carbon Fiber Blades x 1 set
●120mm Fiber Tail Blades x 1 set
●A13 GST Transmitter set(include A6B Receiver) x 1
●7.5L Chemical Container x 2
●Main Power - 950MX Brushless Motor x 1
●200A ESC Brushless Motor Controller x 1
●AP2 Flight Controller System x 1
●P2 PCU Power Control Unit Set x 1
●1080 DV Two-axis Gimbal Set x 1
●Millimeter Wave Radar x 1
●VTD1 1080 HD Digital Video Transmitter Set x 1
●Obstacle Avoidance Radar System x 1
●High Pressure Spraying System (4L/Min) x 1
●Super Bright LED Front Headlight x 1
●Spraying Tube LED Light-White x 2
●Screw Driver x 1 set
●Ball Link Plier x 1
●8" Hood for Tablet x 1
ALIGN E1 PLUS Product Specification
●Body Length:1587mm
●Body Height:570mm
●Body Width:427mm
●Main Rotor Length:830mm
●Main Rotor Diameter:1846mm
●Tail Rotor Diameter:313mm
●Empty Weight:Approx. 13.7kg(w/6S 12000mAh Battery x2)
●Takeoff Weight:Approx. 24kg (with 10L chemical container)
●900MX Brushless Motor
●Max Output Power:5100W/11000W(2sec)
●Chemical Container:15L
●Maximum Working Speed:8M/sec
●Spray Efficiency:Spray up to 0.48 acres per minute (1 acres per= 4046 Square meters)
●Spray Operation Flight Time:(Payload : 10L ; Flight Currency : 60A)
 Approx. 17min.(w/12000mAh Battery/900mm Blades)
 Approx. 20.5min.(w/16000mAh Battery/900mm Blades)
●Flight Time Without Payload:(Included spraying equipment / Currency : 30A)
 Approx. 20min.(w/12000mAh Battery/900mm Blades)
 Approx. 25min.(w/16000mAh Battery/900mm Blades)
●High Pressure Spray System
  • Atomized particles:
    SF11002:136~177 Micron
    SF11015:< 136 Micron
Self-provided Equipment
●UP600+ Balance Charger (AC 110V or AC 220V) x 2 set
●Main Power Battery 6S Li-Po 10000~16000mAh x 8 pcs (= 4 set) and more
●PCU Battery 3S 2200~3300mAh x 2 set and more
● ALIGN Flying Simulator for flying practice.
●8" Tablet
  • * AP2 Flight Control System supports Android 8.0 and 9.0.
  • * Considering the best working efficiency, the specifications of the tablet are recommended as follows: 8” Tablet, 6 Core CPU, 3GB RAM, more than 32GB ROM storage space and support 5G Wi-Fi.
  • * The max. dimension of screen bracket is 240 x 169mm.
●Tablet Suggestions:
  Samsung Galaxy Tab A /Model Type:SM-T385
  Samsung Galaxy Tab A 8.0 /Model Type:T295 (LTE)
  Samsung Galaxy P200
  Samsung Galaxy Tab A 10.1 /Model Type:SM-T510
  Mi Band 4
  ASUS ZenPad 3 8.0 /Model Type:Z581KL
ALIGN E1 PLUS Specification
A13 GST Transmitter
●Channel: 14 channels
●Model Type: Helicopter / Multicopter
●RF Range: 2.4055~2.475GHz
●RF: < 20dBm
●System Mode: 2.4G system AFHDS
●Power: Built-in 2S 7.4V 8700mAh Li-Polymer Battery
●Working Hours: Around 6.5 hrs after fully charged
●Display: 128x64mm
●Transmit Distance: In the air without interference <1000M
●Weight: 650g
●Dimension: 167x180x103mm
●Certificate: FCC, NCC(CCAK19LP0390T9)
A6B Receiver
●RX Sensitivity: -105dBm
●RF Range: 2.4055 ~ 2.475 GHz
●Power: 4.0 ~ 8.4V
●Weight: 14g
●Dimension: 46.7x25.5x13.6mm
●Certificate: FCC, NCC(CCAK18LP1930T2)
●Input Voltage:DC 6-8.4V
●Operating Current Consumption:< 300mAh @ 6V
●Operating Frequency:180MHz
●Operating Temperature:-20°C ~ 65°C(-4°F ~ 149°F)
●Hovering Precision (Depending on Satellite Status):Horizontal ±1m(3.28ft),Vertical ±0.5m(1.64ft)
●Maximum Flight Speed:8M/sec
●Maximum Altitude Restriction:300m(984ft) above the takeoff point
●Maximum Angular Speed:Aileron/Elevator 200°/sec, Rudder 400°/sec
●Maximum Tilting Angle:40°
●Supports Helicopter Configurations:ALIGN E1 / G1
●Dimension:43.8x35.5x20.4 mm
●Working Frequency:5~5.9Ghz
●Way of Transmission:SDR Wireless Transmission Frame
●Wide Transmission Distance:1.5~2km
●Emission Power:200mw(23dBm)
●Power Consumption:Transmitter < 2.5W,Receiver < 2W
●Latency:< 40ms
●Video Output:1080P/720P HD Digital Video Transmission
●Mobile Phone/Tablet:Android and Flight Controller OSD Display
●Antenna:5dB Circular Antenna
●Dimension:66x62x13mm
●Weight:41.8g
●Input Voltage:12S
●Max Continuous Current:120A/250A(2sec)
●Max Output Power:5300W/11000W(2sec)
●Stator Arms:12
●Magnet Poles:10
●Dimension:6x56.7x117.5mm
●Weight:663g
●Emission Frequency:24 Ghz
●Emission Power ( EIRP ):20 dBm
●Measurement Accuracy:5cm
●Update Rate:94Hz
●Working Temperature:-25℃~85℃
●Dimension:80.7x80.4x15mm(HxWxD)
●Weight:82.8g
●Input Voltage:7.4V~12.6V
●Operating Frequency:168MHz
●Operating Temperature:-20°C~65°C(-4°F~149°F)
●Dimension:49.5x40.5x26.8mm
●Working Voltage : 5~12V
●Image Output: 1080P 30fps
●Lens Angle : 130°
●Aperture: F2.0
●Support Low Light Compensation, 3D/2D Dynamic Noise Reduction, Auto Exposure, Auto Focus, and Auto White Balance
●Capable of Gimbal Control Angle: 0° ~ -90°
●Dimension:100.4x74x111.5mm
●Pump Supply Voltage:12~16V
●Pump Power Consumption:3A
●Flow Detecting:Chemical Volume Spray Detecting
●Flow Control:Spray Calculator( 0~4 L/min )
●Container Volume:15L
●Pump Control:Spray Amount Setting( 0~4 L/min )
●Pump Max. Operating Pressure:5.5 Bar
●Transmission Frequency:24GHz
●Power Consumption:400mW
●Detection Range:0.5~25m(Depend on target size and material)
●Detection Angle:Horizontal 34 degree / Vertical 34 degree
●Effictive Flight Condition:
  Flight Altitude over 1.5m
  Flight Speed lower than 5m/s
●Start Safe Braking Distance:6m
●Safe Braking Distance:2~3M
●Approaching Direction:Forward-looking
ALIGN E1 Drone Wind Tunnel Test
AP2 Download
Flight Safety
