Focus Shots
Standard Equipment
●M460 Mission Drone Kit Set x 1
●AP3 Flight Control System x 1
●GNSS Remote Receiver x 1
●Transmitter x 1
●6S 6000mAh Intelligent Battery x 1
●Balance Charger x 1
●Enhanced Control Hook x 1
Product Specification
●Airframe Diameter: 670mm
●Height: 290mm
●Foldable Rotor: 7.5 Inches
●Propeller Diameter: 415mm
●Power System: RCM-BL4213 Motor(370KV)
●Max. Flight Distance:1.5km(no interference)
●Max. Flight Altitude:500M
●Max. Speed:20M/sec
●Frame Weight: 2.5kg
●Flying weight: 3.33Kg (including battery 6000mAh)
●Max. Takeoff Weight: 7kg
●Flight Time: Approx. 22min (no load)
●Wind Force Scale: Level 7
●Airstop Accuracy:
  Vertical:±0.5M (GNSS signal normal)
  Horizontal:±0.5M (GNSS signal normal)
Optional Equipment
●G3P 4K 3-axis Gimbal / G2A 1080 2-axis Gimbal
●Obstacle Avoidance Radar
●VTD1 1080 HD Digital Video Transmitter Set
●6S 10000mAh Intelligent Battery
Flight Safety
