Top » Home Shop » RC World » Helicopter » Charger/Batteries » Batteries » HBP25001
US$ 36
Li-Po Battery 3S 2500mAh
HBP25001
US$ 27.99
Appearance:
●Use for T-REX 450LP.
●Continuous Discharge: 25C.
●approval(GTK-0504008)、approval(GTK-0504008)。
NOTE:
●Output:11.1V 2500mAh 27.8Wh (3S1P)
●Support 5C charging.
●Dimension:33x104x24mm
●Weight:188g
●T Connector
This Product was added to our catalog on Thursday, 05. October 2023.
