Top » Home Shop » RC World » Helicopter » Charger/Batteries » Batteries » HBP25002
US$ 75
Li-Po Battery 2S 2500mAh
HBP25002
US$ 18.99
Appearance:
●Suitable for : 600~800 Series External BEC Power Supply.
●This Li-poly battery features high efficient and high discharge, use a inspection machine to match packs.
●Continuous Discharge: 25C.
●approval(GTK-0504008)、approval(GTK-0504008)。
NOTE:
●Output:7.4V 2500mAh 18.5Wh (2S1P)
●Support 5C charging.
●Dimension:34x106x16.5mm
●Weight:125g
●T Connector
This Product was added to our catalog on Thursday, 05. October 2023.
